TRANE Air Handler Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 02:41 PM   #1
TRANE Air Handler problems
The fan motor only works when the cover panel is removed... not sure what the issue is. The motor sounds weak when it starts up, could it possibly be a relay? I honestly have no idea. It's a 1985 TRANE model. I would appreciate any input. thank you
rustynails36 is offline   Reply With Quote
Old 02-01-2013, 05:11 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
With the limited data you offer I will guess maybe a bad capacitor?
PoleCat is offline   Reply With Quote
Old 02-02-2013, 08:43 AM   #3
An old Tradesmen
Rewards Points: 6,140
Relay probably wouldn't work with the panel off any better then it would with the panel on.
Check capacitor as said above.
Old 02-06-2013, 10:47 AM   #4
changed the capacitor, still having the same issues... When i remove the cover that accesses the fan and then turn on the air handler it works. So then i replace the cover and it continues to work until the next time the air handler kicks on and tries to heat the upstairs... it sounds like a noise is coming from the fan motor area... it's an annoying buzzing/humming sound with some crackling noises.... do i need to change the fan motor?
Old 02-06-2013, 10:48 AM   #5
also, i had the capacitor checked and it was a little weak so that's why i changed it...
Old 02-06-2013, 04:38 PM   #6
An old Tradesmen
Sounds like a wire is being moved or pinched when you close the panel.
Old 02-07-2013, 08:53 AM   #7
PoleCat's Avatar
Burned contacts on an old relay can give good and bad connections intermittently. Plus you may also want to rule out contact with wiring or blower when closing the unit.
Tags
air handler , trane
Trane / American Standard air handler blower fan never shuts off Flt_Simulation HVAC 7 09-20-2012 02:34 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Trane XL90 Annual Problems C63 HVAC 2 10-20-2008 06:01 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
