-   -   TRANE Air Handler problems (http://www.diychatroom.com/f17/trane-air-handler-problems-170753/)
rustynails36 02-01-2013 02:41 PM
The fan motor only works when the cover panel is removed... not sure what the issue is. The motor sounds weak when it starts up, could it possibly be a relay? I honestly have no idea. It's a 1985 TRANE model. I would appreciate any input. thank you
PoleCat 02-01-2013 05:11 PM
With the limited data you offer I will guess maybe a bad capacitor?
beenthere 02-02-2013 08:43 AM
Relay probably wouldn't work with the panel off any better then it would with the panel on.
Check capacitor as said above.
rustynails36 02-06-2013 10:47 AM
changed the capacitor, still having the same issues... When i remove the cover that accesses the fan and then turn on the air handler it works. So then i replace the cover and it continues to work until the next time the air handler kicks on and tries to heat the upstairs... it sounds like a noise is coming from the fan motor area... it's an annoying buzzing/humming sound with some crackling noises.... do i need to change the fan motor?
rustynails36 02-06-2013 10:48 AM
also, i had the capacitor checked and it was a little weak so that's why i changed it...
beenthere 02-06-2013 04:38 PM
Sounds like a wire is being moved or pinched when you close the panel.
PoleCat 02-07-2013 08:53 AM
Burned contacts on an old relay can give good and bad connections intermittently. Plus you may also want to rule out contact with wiring or blower when closing the unit.
