Trane Air Handler Leaking A Ton Of Water - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 08:25 PM   #1
Rewards Points: 150
Trane air handler leaking a ton of water
Let me start by saying I don't know much about HVAC so if you need more info let me know and I will provide it. I just bought a house and it has a Trane air handler model number TWEO24P130BO. Whenever we run the AC it leaks water like a drippy faucet.
The unit is installed in my basement and mounted up off the floor in a horizontal position. The water all seems to be coming from the are where 3 brown wires exit the air handler. Its obviously causing moisture issues in the already damp basement.
Can anyone give me any idea where to start looking or what this could be??
I really appreciate the help.
organick is offline   Reply With Quote
Old 08-11-2010, 09:00 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
Post some pics of the problem.
Old 08-11-2010, 09:31 PM   #3
In A/C mode the air handler is removing humidity from the air and it needs a place to go. Your condensate drain pan, P-trap, drain line or pump could be clogged or inoperative.
It's likely to be something fairly simple.
hennyh is offline   Reply With Quote
Old 08-11-2010, 10:21 PM   #4
Rewards Points: 150
I can get some pics tomorrow but there isn't much to see except the water dripping out of that wire hole. I will def. post some though because it may mean alot more to someone else...
hennyh.....what would be my best next step to determine if it one of the things you said??
Thank you both.
Old 08-11-2010, 10:56 PM   #5
Thank you both.
I'd inspect the PVC condensate pipe from the air handler to the drain. It might have an inspection plug near the P-trap or maybe you can remove the fitting to the AH.
If the run is clear then you may have a cracked air handler condensate pan.
You might also hook up a wet/dry shop vac to the end of the drain line and try and suck it out. It's common the the P-trap to get clogged with mold or other crap.
Old 08-12-2010, 07:29 AM   #6
biggles's Avatar
shut the unit off pop the air handler panel(s) and reach into the condensate pan to feel all the muck your over flowing the pan and the insulation under the fan is soaked??.the water in that pan should free flow out thru the trap ..before cutting the PVC tap the line all around the trap with the cond.pan full might loosen the blockage and flow out
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
