Trane AC - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 02:13 AM   #1
Trane AC
where do you find a fuse for the 24v ac supply on a trane heat pump?
its a trane model wch042b100ca, a 2003 model.
I replace the orginal trane thermostat with a newer programable unit.
wires match up to new unit...now nothing works...no 24v ac on terminal connections on the new thermostat.
thanks
vandy60
vandy60 is offline   Reply With Quote
Old 08-03-2009, 07:13 AM   #2
biggles's Avatar
at the air handler the TR is either protected from a mimi circiut breaker on the back of the TR or if the 24Vs goes out to a board the fuse might be there to protect the board where the stat wires land from up stairs stat.if you seen nothing the 24Vs might have a one time fuse link inside the coil 24Vs side need a new TR
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 11:46 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
