Old 11-06-2010, 02:34 PM   #1
TRANE 90 xe High Limit Error -still....
Hi my LP furnace is mounted horizontally under a crawl space, fan blows, no fire, 4 LED flashes so I replaced the high limit switch and the filter. Still 4 flashes (high limit switch) and no fire. Also checked the condensate drains.
I am starting to think the board is shot, anyone have ideas of other things I can check.
Appreciate any ideas.
Bruce
BruceDJames is offline   Reply With Quote
Old 11-06-2010, 04:48 PM   #2
NEvermind, it finally must have reset the high limit switch, I re-powered the furnace and it started up with continuos flashses(call for heat) and then fired up. I'll monitor and see how it runs over the next few hours..
Bruce
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 11:46 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Trane Excecutive High Efficiency Furnace Help kashimama HVAC 2 09-01-2009 07:46 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 12:33 PM
