Trane 1200 Xl Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 09:30 PM   #1
KJK
Trane 1200 xl problem
I have a Trane 1200 xl, age unknown. When the air kicks on, the fan on the compressor unit (outside) runs immediately. It seems to not engage the compressor, though. Then, I'll hear a heavy electrical thump, like a sudden draw on amperage as if the compressor is starting. But, it only lasts for about a second, then stops. It will do this about once a minute for 5 or 10 minutes. Then, it will do it again, but the compressor will kick on and I'll be able to hear the heavier working of the unit. When working, it seems to cool fine- air out the vents is about 15 degrees cooler than ambient. This is a kind of intermittent problem, but becoming more frequent (every day, but not every cycle). Any ideas? The breaker at the main box was tripped once about 3 weeks ago, but not since. Been in the house 6 years.
KJK is offline   Reply With Quote
Old 08-20-2013, 10:17 PM   #2
Rewards Points: 616
need to check lots of things.... supply voltage... electrical connections.... capacitor... just to name a few....
carmon is offline   Reply With Quote
Trane XE 1200 Fatdaddy212 HVAC 6 04-16-2013 03:31 PM
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 5 08-07-2012 01:53 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Trane XE 1000 Fan Problem Flathead64 HVAC 15 07-01-2009 09:08 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
