Trailer Hell - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 11:18 PM   #1
trailer hell
I am renovating a trailer. When the furnace kicks in , the range hood blows cold air into house. what can i do ?
denslyman is offline   Reply With Quote
Old 04-21-2011, 12:50 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Put your bed under the range hoOd.
Doc Holliday is offline   Reply With Quote
Old 04-21-2011, 05:40 AM   #3
Rewards Points: 1,216
Make sure there's a air flap check installed outside to prevent air from being drawn into the hood from outside. You know they have them on dryer vents.
COLDIRON is offline   Reply With Quote
Old 04-21-2011, 06:13 AM   #4
Sounds like you have a huge supply air leak going outside and it's using the range hood to replace that air.
Old 04-21-2011, 06:36 PM   #5
An old Tradesmen
Rewards Points: 6,914
Yep, a real big one from the description.
Old 04-21-2011, 11:20 PM   #6
Your furnace requires combustion air. If it has a blockage of its air supply, air will be drawn in from any outside opening.
The flapper on the range hood vent, should be closed unless the fan is running.
Enclosed Utility Trailer Project jpn735361 Automotive Repairs 2 01-16-2011 10:10 AM
trailer in my living room (must read) wengang1 Remodeling 0 01-19-2010 03:30 PM
Trailer Brakes NEED HELP plz Jeepster Automotive Repairs 4 09-13-2009 06:45 PM
New Trailer service hd82 Electrical 10 04-23-2009 12:26 PM
Trailer brakes bucksone Automotive Repairs 1 09-01-2007 07:47 PM
