-   -   trailer furnace on blocks in garage (http://www.diychatroom.com/f17/trailer-furnace-blocks-garage-33880/)
creek1369 12-16-2008 04:29 PM
I'm putting a trailer furnace,miller mod 80,in the garage.I want to use a block foundation to lift it up and vent it to the floor,do I need to close off the bottom of the furnace at the motor?Common sense tells me I should and cut some vents in the front of the body to vent the motor.Also,is it required to have a dampner,or vent the exhaust straight out ok??Does the length of the exhaust vent matter?? Thanx folks.
beenthere 12-16-2008 06:12 PM
Use to use hollow cement blocks to do what your doing.
Unless it was not desirable to have teh air blowing out all 4 directions.
Make sure you have it high enough that the burner motor is 18" above the floor.
Yes, block off the bottom combustion air inlet, and cut a hole on the side of the jacket. Put a mesh screen over it.
creek1369 12-16-2008 10:07 PM
beenthere..do i NEED a dampner?
Thanks buddy,I appreciate the comeback on the trlr furnace/garage/blocks,does the motor have to be 18" off the ground?Im limited on height,how about the ex vent,do I need a dampner?Can the ex vent go straight up or curve 90 out 90 up?I dont know if I need a dampner/flue whatever that vent/flap thingamajingy is technically called
beenthere 12-17-2008 04:34 AM
Code for garage requires all sources of ignition to be a min of 18" above the floor.
Since a motor can spark, it is a source of ignition.
You should have no trouble if you ell over and then ell up.
Providing its not too far over.
You will want a barometric damper.
It will work without one, but a damper will help keep the flame lower in the combustion chamber, and burn a little cleaner.
creek1369 12-17-2008 06:18 AM
hey been there,18" it is,ells and dampner,thanx buddy!
