Tough Decision Need Help Choosing Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 10:50 AM   #1
tough decision need help choosing boiler
I just bought my first house, a two fam in North NJ. I am renovating the second floor (upstairs). Its about 600 sq ft, two bedroom one bath. I just sized it up for baseboard heat and already started running it. There is about 50' of baseboard (heating element) and according to the calculation I should only need 30,000 BTU's for that. I don't want to vent through the chimney. I was looking at direct vent units and found that I have a few options. First was the traditional boiler and hot water heater.
But now the local plumbing supply is recomending the Ambassador wall mount combination gas heater. Its a boiler and hot water heater in one. I need to make a decision very soon so I can finish this project and get tenants in. It seems to be rated for what I need, its on the wall out of the way... I just cant find anyone with experience with these. Any insight will help me out a lot thanks. -Ray
mynd66 is offline   Reply With Quote
Old 11-23-2008, 04:03 PM   #2
An old Tradesmen
Rewards Points: 6,576
Not familar with that unit.
Double check its hot water rating.
You don't want tenants complaining they can't take a hot shower when the heat is running.
Old 11-23-2008, 08:18 PM   #3
They have 2 models. The hot water ratings are as follows: Gal/Min (60 degrees) = 2.5 and for 75 degrees its 2.0. The other model is 2.6 and 2.1 and these ratings are for continuous flow. Not sure exactly how to interpret that but its supplying one kitchen sink and one full bath. There couldn't be less to supply hot water to. Yet I'm wondering how it will do on the coldest days while the heat is cranking.
I still can't find anyone who has any knowlege of these, I don't want to be the guinea pig. Thanks for the reply.
Old 11-23-2008, 08:31 PM   #4
An old Tradesmen
You should probably use a staorage tank with either one of them.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 10:01 AM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 12:49 PM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 06:26 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 07:18 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
