Old 05-16-2007, 12:06 PM   #1
Totaline to Honeywell tstat
Hi guys,
I've got a gas furnace and electric A/C with a Totaline P4740100 thermostat that I want to change out. The new thermostat is a Honeywell CT8602C.
The current wiring is:
Red - R
Green - G
Yellow - Y1
White - W1
Brown - C
The new thermostat doesn't have the connection for the "C" installed in it. Can anyone tell me how to hook this up?
I've looked through both of the manuals, but couldn't find anything that explained what to do with the brown wire...
Thanks,
Mike
rockout0 is offline   Reply With Quote
Old 05-16-2007, 01:28 PM   #2
Apparently the common is only to run the display on the thermostat, and since this thermostat seems to only run on batteries, the common is not needed.
switching from Honeywell to Totaline novadude HVAC 2 05-13-2007 10:09 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 03:27 PM
Help need on honeywell 8600 rlvarcoe HVAC 2 11-21-2006 05:03 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
