Total Effective Length Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 07:26 PM   #1
Rewards Points: 150
total effective length question
when calculating the total effective length for a branch, does the size of the fitting change the effective length? for instance, a fitting that transitions from a round duct, up 90 degress to a rectangle register has an effective length of 30. does that number change if the round duct is 6", 7", or 8"?
i assume not, because the whole point in doing this calculation is to determine the duct size. it just seems that if the duct were wider, the fitting would cause less resistance.
drewhart is offline   Reply With Quote
Old 01-27-2009, 08:51 PM   #2
An old Tradesmen
Rewards Points: 6,576
The transitions are calculated to be pretty much standardized.
They aren't actually, but close enough.
The PD changes if the radius changes.
And it will also change if you run above average FPM.
Old 01-27-2009, 09:46 PM   #3
JohnH1's Avatar
A larger size can reduce the resistance but then you will lower the velocity wich is why you are doing proper duct design to begin with. You want the proper cfm as well as the proper velocity.
JohnH1 is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
total air tool beginner question (real e-z) amakarevic Building & Construction 4 12-30-2007 09:56 PM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
