Torry61 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 06:46 AM   #1
torry61
New guy here, How do I propperly releave the pressure in a central air unit, & can I use the same line set on a new unit? The old unit is about 25 years old.
Tor
torry61 is offline   Reply With Quote
Old 11-02-2010, 07:01 AM   #2
fabrk8r
fabrk8r's Avatar
The refrigerant in the system needs to be recovered using proper refrigerant recovery equipment.
*Warning, venting refrigerants into the atmosphere from most existing AC systems is illegal*
Chances are that your old system contains R22 refrigerant. A new residential system will use R410-a. The two refrigerants are incompatible and the lineset should be changed. Let me know if you want me to list the reasons why.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 11-02-2010, 07:07 AM   #3
R U aware if the recovery equipment can be rented? I live in the Chicago area?
Old 11-02-2010, 07:24 PM   #4
An old Tradesmen
Rewards Points: 6,870
Yes. You can rent recovery equipment.
You need an EPA section 608 certification to rent it though.
