Tons - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2009, 08:11 PM   #1
Tons
How do you figure what ton unit (heat pump) to use. Is it based off the heated square footage of the home.
Toolmaster is offline   Reply With Quote
Old 06-01-2009, 08:20 PM   #2
An old Tradesmen
Rewards Points: 6,944
Use HVAC CALC. Its advertised on this site.
Old 06-01-2009, 08:27 PM   #3
Here's another source,
http://www.vonwentzel.net/HVAC/HVAC-...ors/index.html
and most libraries have books on this subject, either to loan or as reference books.
The calculations are very tedious.
Old 06-02-2009, 07:21 AM   #4
As a ball park estimate you can use the rule-of-thumb of sq ft per ton, but for a home run get a copy of Manual J from your local library, or as been has suggested buy HVAC-CALC. Once you see what variables Manual J considers you will understand why sq ft per ton is inadequate.
dac122 is offline   Reply With Quote
Old 06-02-2009, 10:58 AM   #5
For heating of single family homes, some heat loss values are
.....x......x.x..x.....x.x
0.....|.....|.....|.....|....|
..............................10
where the units are
BTU/sq. ft./HDD
The 1.7 on the left is probably the best that anyone can do. My leaky old house comes in at 8.0. If additional, future data that I collect follows the same pattern you can be reasonably assured that most houses fall between 1.7 and 9 BTU/sq. ft./HDD, with newer houses being tighter.
If anyone has similar data for single family homes for cooling (heat gain) normalized to house sq. footage and cooling degree days I'd like to see it. When I had the 1985 Manual J in my hands I should have used the house in their example.
The cooling datapoints will probably be scattered more than above because the COP varies with outside temp, but oil/gas appliances have a more or less constant efficiency.
There should be some (loose) connection between the heating and cooling load since they're both related to insulation value.
Old 06-02-2009, 05:25 PM   #6
An old Tradesmen
Nope.
Heating is calculated with no solar gain(middle of the night).
Cooling calculated with solar gain(hotest part of the day).
So no real correlation.
Old 06-02-2009, 05:48 PM   #7
Originally Posted by beenthere View Post
Nope.
Bit by bit I learn the hands-on of HVAC.
So some of the scatter in my data is due to solar heating and the Manual J calc. is pessimistic since it assumes no insolation?
Old 06-02-2009, 06:03 PM   #8
An old Tradesmen
Manual J doesn't assume no insultation. It has HTM for multiple insulation values.
The new ver 8 also takes into consideration radiant barriers.
How many tons Trane XR12 pcampbell HVAC 2 06-09-2008 04:53 PM
Finishing the basement- tons of insulation questions QueenL Building & Construction 2 04-01-2008 01:25 PM
only 3 Tons for 3700 Sf Ft? 1K2GO HVAC 7 11-23-2007 06:13 PM
Very Newbie with tons of questions Aerovette Building & Construction 37 06-13-2007 10:04 PM
figuring what tons are needed pbuzz3323 HVAC 2 07-31-2006 06:40 PM
