Tonnage Help - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 10:19 PM   #31
I'm Your Huckleberry
Rewards Points: 2,270
Remove the blower squirrel cage and motor and clean all of it. Any dirt on the blades and in the housing and on the motor will restrict air flow.
Open the return and supply plenums and vacuum them out as well.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-11-2012, 05:19 AM   #32
jkv
After you clean all that Doc ask you to clean get your teacher at school involved if he is anything like mine was he will get the whole class on it and dont miss any cleaning its good learning. Can you put gauges on yet? If so check your superheat and subcooling if you have a txv charge by subcooling
jkv is offline   Reply With Quote
tonnage help darkened08 General DIY Discussions 3 08-12-2012 12:35 PM
What tonnage / seer / Heat Pump? shank HVAC 3 07-17-2011 10:40 AM
Help Determining Age and Tonnage of AC frankleibo HVAC 8 06-03-2011 07:26 PM
trane tonnage air man HVAC 3 04-13-2011 10:20 PM
