Tonnage Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 08:51 PM   #16
HOTDAWG
Was it working fine previously or has it always sucked?
Acomfort is offline   Reply With Quote
Old 08-09-2012, 08:53 PM   #17
Its always sucked. I've run out of options other than getting up there and taking a look myself
darkened08 is offline   Reply With Quote
Old 08-09-2012, 08:56 PM   #18
HOTDAWG
if its always sucked then it could be dirty coil, duct work or low charge.. like turnermech already said,... unfortunately your gonna have to dig a little deeper
Old 08-09-2012, 09:35 PM   #19
Originally Posted by darkened08 View Post
I'm pretty sure there's some duct work needed. Near thr back of he house where the closet is is fairly cool but in the front of the house its like the air isn't even on. There's at least a four or five degree difference just walking down the hall
if you have no air flow in that area that would be the first thing I would check. Judging by the name plate you posted it is a 1989 unit. Assuming that the entire system is that old duct work could be apart going to that location.
The size of the unit may not be big enough or it may be just right. You must fix any other problems to know. No air flow at part of the home would be first place to start.
turnermech is offline   Reply With Quote
Old 08-09-2012, 09:44 PM   #20
Thank you for the help all. How did you come up with an 89 unit? I'll update tomorrow morning with what I find up there. If its too bad I'll get some pictures
Old 08-09-2012, 09:53 PM   #21
name plate has MFR Date (manufacture date) 1/89
Old 08-09-2012, 09:56 PM   #22
Can believe I missed that. Lol. I was more looking at the tonnage than the date I suppose but as I said, I'm going to get up there early tomorrow before class and see what I'm dealing with
Old 08-10-2012, 07:36 AM   #23
Rewards Points: 582
system was probley ok at install but because its a rental haven't been taken care of like it should....my guess its plugged with dirt restricting its ability to cool....dirty..coil,condenser..low freon,etc......recommend good cleaning to start with...inside and out....check temps and pressures.. go from there
Old 08-10-2012, 07:15 PM   #24
Those are the top of the furnace where they sheet metal conneacr to the coil housing. Massive amount of air pouring out. Used duct tape for a temp fix
Old 08-10-2012, 07:16 PM   #25
Some of the rips where insulation is hanging out. Didn't feel any air coming from them so don't think: there too bad just yet
Old 08-10-2012, 09:27 PM   #26
duct looks to be leaking for sure, but i don't see enough leakage to acount for no air flow to the front section of your home. Do you not have air flow in the front section of the home? or did i misunderstand previous post?
Old 08-10-2012, 09:37 PM   #27
You didn't misunderstand. There is very little to no air flow in the front of the house I closed up the gaps shown and it helped a little. Not much but enough to cool it down a but
Old 08-10-2012, 09:56 PM   #28
Can you acess all the ductwork from the attic? did you look for any dampers in the ductwork? more to the point the ductwork with no air flow?
Old 08-10-2012, 10:13 PM   #29
I did and from the looks of it it hadn't been hanged out since install. The visblr duct didn't seem to have crimps or anything obstructing from the outside. Felt no air blowing out of it. And it moved very little the air kicked on. As I said it has very little air flow. Enough to put your hand an inch or two away and be able to feel it. Just seems underpowered
Old 08-10-2012, 11:16 PM   #30
I'm Your Huckleberry
Rewards Points: 2,270
Not always will the model number state in multiples of 12 the tonnage. Most, not all.
400 or 500 square feet per to is a wives tale. Granted it's a rule of thumb that possibly can steer one in a general direction but never to be used in any scientific heat load calculation by any stretch of the imagination. Envelope is what does it. There's an a/c tech, an aquaintance of beenthere's I believe and close by myself in Dallas, with a 2 ton on a 4000 sq home if memory serves me correctly.
Seal up all leaks in ductwork and perform a static pressure test. Check to see the blower is on high speed. Remove the service panel on to expose the coil. Make sure all internal insulation is intact and not fallen and blocking air. Check the coil while you're in there. Is it filthy? Clean it.
Dampers?
Thanks.
Doc Holliday is offline   Reply With Quote
tonnage help darkened08 General DIY Discussions 3 08-12-2012 01:35 PM
What tonnage / seer / Heat Pump? shank HVAC 3 07-17-2011 11:40 AM
Help Determining Age and Tonnage of AC frankleibo HVAC 8 06-03-2011 08:26 PM
trane tonnage air man HVAC 3 04-13-2011 11:20 PM
