Tonnage Help - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 06:45 PM   #1
tonnage help
Hello all, I'm currently going to school for hvac/r its gotten me curious about mine. I want to know the tonnage on my unit to see if that is one of the causes of the massive heat inside the house (other than the hear outside. In Ms. Were lucky to get below 95 )
darkened08 is offline   Reply With Quote
Old 08-09-2012, 06:50 PM   #2
HOTDAWG
Looks like a 2 ton
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
darkened08 (08-09-2012)
Old 08-09-2012, 06:50 PM   #3
2 ton, 24,000 btu
turnermech is offline   Reply With Quote
The Following User Says Thank You to turnermech For This Useful Post:
Old 08-09-2012, 06:51 PM   #4
Call it a tie
Old 08-09-2012, 06:51 PM   #5
Rewards Points: 582
Attachment 55561
I think it a 2ton 24,000 btu... what size do you need ...have a load calulation been done ... have it been serviced to see if its running right.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 08-09-2012, 06:52 PM   #6
HOTDAWG
In the model number there will always be a variation of 12, being 12,000 btus of cooling.. ie: 1.5 ton would be 18, 2 ton 24 and so on
Old 08-09-2012, 06:52 PM   #7
Rewards Points: 582
can't type that fast3 way tie
Old 08-09-2012, 06:53 PM   #8
Thank you. Got in an argument over it with my landlord. Its a constant 78-80 inside the house. I don't expect it to get down passed even 75 maybe but two or three degrees makes a huge difference. My house is somewhere along the line of 1250 sq. Ft i believe. As I said I'm a student learning it and I was told it should be roughly a ton per 400 sq. Ft
Old 08-09-2012, 06:54 PM   #9
HOTDAWG
I'm in canada, so we don't need quite that much, but I think in the states there you guys are roughly 500 per ton
Old 08-09-2012, 07:25 PM   #10
square footage to tons is realy just a EWAG better than a WAG but not that much. But it is 500 to 600 sq ft per ton around here.
Old 08-09-2012, 07:33 PM   #11
So is what I have the right size? Maybe half a ton bigger but thatd be a lot of money for a little change.
Old 08-09-2012, 07:36 PM   #12
the first thing would be to see if the unit is operating corectly. refrigerant charge, duct work leak, dirty condenser coil ect..
Old 08-09-2012, 07:39 PM   #13
I'm pretty sure there's some duct work needed. Near thr back of he house where the closet is is fairly cool but in the front of the house its like the air isn't even on. There's at least a four or five degree difference just walking down the hall
Old 08-09-2012, 07:42 PM   #14
HOTDAWG
simplest fix is to check your filter
Old 08-09-2012, 07:48 PM   #15
We've just changed it maybe a week or two ago in hopes that fix it.
tonnage help darkened08 General DIY Discussions 3 08-12-2012 12:35 PM
What tonnage / seer / Heat Pump? shank HVAC 3 07-17-2011 10:40 AM
Help Determining Age and Tonnage of AC frankleibo HVAC 8 06-03-2011 07:26 PM
trane tonnage air man HVAC 3 04-13-2011 10:20 PM
