Toe Kick Register - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2015, 10:28 PM   #1
In a little over my head
Rewards Points: 688
toe kick register
Hi all,
I'm remodeling my kitchen, and moving the heat/ac register from the floor to a cabinet toe-kick. The cabinet is 24" wide, with a clear space underneath between the joists in a crawl space. Cabinets are IKEA with (I think) leveling legs and separate toe kicks. Existing duct is a short piece of round insulated flex.
I've looked at some old threads here. And, I have found the "toe ductor." http://toekickductor.com/
But that seems expensive and more than I need.
How would you do it?
ratherbefishing is offline   Reply With Quote
Old 05-13-2015, 05:45 AM   #2
Rewards Points: 1,158
toe kick register
Looks to me exactly what you need. By the time you buy the proper parts IE: Duuctwork, screws, tape, registers , ETc.
Once it's done it's done forever you never have to worry about it and you will be glad you paid the little bit of money for it. Just do it.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ratherbefishing (05-13-2015)
Old 05-25-2015, 12:58 AM   #3
Rewards Points: 688
toe kick register
Just to follow up, I bought the ToeDuctor. It worked great. Once the floor register was moved to under the cabinet, installing the kit took twenty minutes. Freed up time to do something else. Kitchen is coming right along.
The Following User Says Thank You to ratherbefishing For This Useful Post:
COLDIRON (05-25-2015)
Old 05-25-2015, 10:16 AM   #4
Rewards Points: 4,248
toe kick register
how much is that setup ? i just made a duct from plywood, sealed with weather stripping to toe kick. pushed in register. works awesome.
Fix'n it is offline   Reply With Quote
Old 05-26-2015, 08:02 PM   #5
Rewards Points: 688
toe kick register
Fix'n it, that's the way I was thinking of doing it. I decided to spend money to save time. The ToeDuctor was 80 bucks with shipping.
Old 05-26-2015, 08:31 PM   #6
toe kick register
80 bucks, ouch. had i known about it, i still would have made one.
Old 05-27-2015, 06:15 AM   #7
toe kick register
rather, you did it the right way. Ductwork was invented for a reason. Wood is not supposed to be used to distribute hot/cold air. Many reasons just one or two. Wood dries out and warps, if there's a fire it is somewhat confined " not totally", to much friction for proper airflow, cannot be sealed properly like ductwork. Wood joist space is sometimes used for return air back to the heater/AH if convenient by panning material in the basement but it's rare today. To each their own. I would do it the way you did or buy the fittings and end up with what you have.
ratherbefishing (05-27-2015)
Need to close the gap between my new vanity's toe kick and my tile monnjohn Kitchen & Bath Remodeling 11 05-22-2015 07:08 AM
Dark register for toe kick ingeborgdot General DIY Discussions 6 11-14-2010 06:56 PM
Adding new register via tee off existing register tpanc13 HVAC 12 06-30-2010 12:04 PM
How to attach ceiling register to duct? adrianm HVAC 6 03-25-2010 07:29 AM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 05:26 AM
