Old 10-04-2007, 08:13 PM   #1
DeeTee's Avatar
Cool
Tips On A/C Blower Troubleshooting?
I have a home a/c unit that is iced up and the blower isn't coming on. Well, maybe it's more like the blower isn't coming on so the unit iced up. Opening the windows doesn't help much since we're in the middle of a heat wave.
Any tips on troubleshooting would be appreciated.
Thanks.
___________________________________________
Precision is always relative to the surrounding degree of perfection.
News Views Tips Commentary Downloads at the
DeeTee is offline   Reply With Quote
Old 10-05-2007, 12:24 PM   #2
Follow the wires back from the motor and see if the motor is getting voltage when it is set to come on. Check between the white and the other colors. Also look at the capacitor for bulges or oil leakage and the correct uf if you have a meter that will read capacitance.
cjett is offline   Reply With Quote
Old 10-05-2007, 09:08 PM   #3
DeeTee's Avatar
Thanks Cjett. So far it appears to have been a loose electrical connection. I think it was where three wires came together in an under-sized wire nut. But just guessing there. ANyway, it's a lot cooler tonight.
Old 10-06-2007, 11:56 AM   #4
Glad you got it going. It's hot in SW Ohio at present too so I know the feeling.
Old 05-20-2009, 11:52 PM   #5
I'm having a similar problem. Although the blower runs on a heating cycle and when I switch to Cool it doesn't run. Any suggestions?
miggargie is offline   Reply With Quote
Old 05-21-2009, 07:54 AM   #6
HVAC / Plumbing
Does the blower come on when you switch thermostat to FAN ON ??
kenmac is offline   Reply With Quote
Old 05-21-2009, 08:10 AM   #7
Thanks for the response. Yes, it does go on.
Old 05-21-2009, 01:24 PM   #8
HVAC / Plumbing
May be t.stat. When you turn to FAN ON you send the voltage straight to the board for high speed fan for cooling
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 11:01 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 01:31 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 10:22 PM
