Timer On Furnace Fan? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 12:15 AM   #1
Timer on furnace fan?
Thanks for reading this, I have a question (but some background first):
We have a natural gas forced air furnace/AC. We used to run the furnace fan all the time, because it would get stuffy in our house. I figured out what the cost was, and we decided to stop that. House got stuffy again. SO, I put a simple relay on a timer, to basically turn the fan on the furnace on and off a couple times a day for a half hour or so. Got it working. Then was outside on a cold day, during the time that the fan was supposed to be running, and hear the air conditioner running also. I did some checking, and yes, the furnace is kicking into AC mode four times a day for a half hour (which is what the timer is set for). I jumpered terminals R and G with the relay. What should I have jumpered to just turn on the furnace fan? Thanks for any advice!
CodySharp is offline   Reply With Quote
Old 04-25-2012, 05:03 AM   #2
An old Tradesmen
Rewards Points: 6,870
Might need to get a different relay, unless yours has a single pole NO, and a single pole NC set of contacts.
Wire like in attached PDF.
Old 04-25-2012, 06:43 AM   #3
Ok, not a problem on the relay. What are you showing on the left and the right of the timer relay?
Thank you for the quick reply and information! I do appreciate it!
Old 04-25-2012, 03:49 PM   #4
An old Tradesmen
LOL... Sorry, thought I labeled them, but oops, didn't. The left would be the thermostat, the right would be the furnace. In the drawing, I only drew the wires that you would be running/changing.
Old 04-25-2012, 05:42 PM   #5
Thanks for the clarification. I came up with that once I looked at things a little more. I thought that I would need to somehow unhook the thermostat when the relay turned on. Thanks!
lint/dust from furnace uksparky HVAC 15 02-16-2012 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
furnace randomly shuts down sspeed HVAC 12 12-17-2008 05:28 PM
