It Is That Time Of Year Again - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 05:20 PM   #1
Rewards Points: 6,652
It is that time of year again
I do not always agree with everything This Old house does or say, but they do bring up some good points about one of the most expensive investments for a home http://www.thisoldhouse.com/toh/how-...3-fall-furnace
Old 09-12-2011, 05:37 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You're in the business and all of that Boston Crap they preach may make sense to you but to me that idea is a lot like the mandatory every-3000-mile-oil-change. You know those "This Old House" boys (and I use the term loosley) are all on the take don't you?
Old 09-12-2011, 05:50 PM   #3
I know the feeling also with the TOH boys. As a homeowner, I realized after I woke up from watching them all the time in the 90's, when I owned a trailer, how overboard or out of scope on some of the projects. I find on here, you get a lot better tips and correct information, than the boards on their site.
I did finally fire up the furnace yesterday to make sure it cycled on heat, since I have the new thermostat. I will not know how good it will be with the settings for swing (1.5) and diff (2.0) that I have it set for on for the ct-50, until I can run it a couple of cycles.
Old 09-12-2011, 05:56 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Bud, I'm not in the Boston area, but I can tell you that in most cases on an annual clean and service call I can prevent problems in the future by just cleaning the equipment. Also, why wouldn't you maintain your hvac equipment? DO you know how much replacement systems are?! Often they are as much as a good used car. Why not spend a little bit of money in preventative maintenance instead of prematurely having to replace your hvac system because you never had it maintained. How would you know that your heat exchanger in furnace may be cracked if it was not serviced professionally? Just because a heat exchanger is cracked doesn't mean it will leak CO. And today's CO alarms are so dumbed down in order to be UL listed to keep from having "false alarms" you may not know the furnace was leaking CO even if you had a CO alarm. Often a good tech can even let you know what is getting ready to fail such as an ignitor before it actually does, so you can either plan to have it replaced or take care of it while the tech is out alleviating a future service call. Just my 2 cents, but I do believe in PREVENTATIVE maintenance.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-12-2011, 06:02 PM   #5
So, Bud and hvactech what is your consensus on pulling the blower motor and getting the dust off of the fins. After 6 years of running, with 1 so far for a/c full time so far, and looking at it just now, it does look like the fins could use a good cleaning, due to the layer of dust on them. Other than that, there are just a few cobwebs in the lower section of our Lennox.
Old 09-12-2011, 06:10 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
My HVAC system consists of electric heat in the ceiling of every room and three window air conditioners. The only squirrel cage I'm familiar with is the one I live in with my wife and son.
Old 09-12-2011, 06:17 PM   #7
Rewards Points: 152
What suggestions do you guys have for maintaining an electric forced air furnace?
burnt03 is offline   Reply With Quote
Old 09-12-2011, 06:27 PM   #8
Same on any unit. If you get a good tech burnt, they will check the electric heating elements, and measure for proper resistance. If the unit is old, they may suggest new elements if they are available. I listen for any squeaks and other unusual sounds, smells, and look it over at least once every month when I pull the filter. The user manual is the best reference for maintenance on the unit.
Old 09-12-2011, 06:28 PM   #9
REP
There is a huge differance between oil fired and gas fired equipment.
There is no such thing as a "clean" oil fired heating unit.
With oil,everything needs to be vacuumed out and cleaned.New filters and nozzle AND setting it up with instraments is needed unless you don't care about effiency.Nobody and I mean NOBODY can set and oil burner by eye.Trying to do so will cost you hundreds every year.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
gregzoll (09-12-2011)
Old 09-12-2011, 07:15 PM   #10
AKA HVACTECHFW
Agreed Rep...
@gregzoll - The blower, unless really caked with debris, should be ok. If you have a lot of dirt buildup on the wheel then your filtration system is not working or you have leaks in the blower compartment.
IT IS WHAT IT IS
Old 09-12-2011, 08:05 PM   #11
When I took it out to clean it, it appeared to be dust we raised, when remodeling the bath, and taking down a wall last Summer, between the Kitchen and Dining room. I had flashbacks when I was getting the dust off of the fins.
Becoming a licensed plumber/electrician amakarevic General DIY Discussions 14 09-26-2010 09:58 AM
Tyvek overlap with replacing siding one wall at a time Numb Building & Construction 54 07-01-2010 10:10 AM
Using A/C for first time after home reno. Not sure if this is normal operation. the punisher HVAC 7 05-25-2010 06:42 PM
16 years old and small leak, time to replace? supermaxhd HVAC 16 05-19-2010 07:09 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
