Old 09-29-2007, 09:47 AM   #1
C+M Electrician
Time for a new furnace
It's time for a new furnace and I have 3 guys quoting
1 Luxaire
2 Keep-rite
3 American Standard
Luxaire and Keep-rite, as I understand, are both sub-standard crap. Wereas the American Standard is pretty good. Is this accurate? What sort of warranty should I expect and any other factors to explore?
p.s. I am looking only at two stage systems.
Thanks in advance for your help
SparkyInCanadaEh is offline   Reply With Quote
Old 09-29-2007, 12:08 PM   #2
concretemasonry's Avatar
Make sure you get a variable speed fan (D.C.).
It will give you added economy and allow a lower temperature setting because of the unifirmity. - When heating, I run it constantly and you never hear it or notice the subtle air movement without drafts.
concretemasonry is offline   Reply With Quote
Old 09-29-2007, 12:33 PM   #3
C+M Electrician
I am aware of the DC Motor although in my experience they tend to be very expensive (around $1000) to replace. The benefit as I understand it is the decreased power consumption. A calculator I found online estimates a savings of up to $300 per year in electriciy costs. It's just hard to justify an additional $1200 upfront.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
