Time Delay Relay - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 08:40 PM   #1
time delay relay
how do i by-pass time delay relay
savanhawkden is offline   Reply With Quote
Old 08-10-2011, 09:34 PM   #2
30 year tech
hvac122's Avatar
Why would you want to do that. What kind of system and delay are we talking about.
hvac122 is offline   Reply With Quote
Old 08-11-2011, 07:40 PM   #3
biggles's Avatar
if it has 2 low voltage wires with the TD cut into inline jump them or remove them and wire nut them together..if you have more then 2 wires with 3 terminals need more info on what is it for
Old 08-11-2011, 08:37 PM   #4
If this is for the compressor I would opt to leave it in. The time delay will help protect the compressor during brown-outs.
Master of Cold is offline   Reply With Quote
Old 08-11-2011, 09:00 PM   #5
biggles's Avatar
my suggestion is only for if its not working if you jump it to see if the compressor comes on from a call from the stat...hope your talking TD and not an uverload KLIXON mounted in the terminal box cover of the compressor
Old 08-11-2011, 09:10 PM   #6
most modern a/c systems have td relays built into the t-stat to stop short cycling...jumping it/eliminating it from the circuit would be ok in this instance as it would be redundant to leave it in.
however if you have the old t87f the "round" t-stat or equivalent jump it to see if the sys. Contactor pulls in...if so the control is n/g and should be replaced....provided that you waited the predetermined time usually 5mins. When initially waiting for the sys. To run.
hope this helps..
SAMCRO is offline   Reply With Quote
Old 08-11-2011, 09:43 PM   #7
Klixon on a resi system?? Just how old are you??
Old 08-11-2011, 09:55 PM   #8
that "klixon" mounted overload, what is that one used for? bigger compressors?
Final Notice is offline   Reply With Quote
Old 08-11-2011, 10:19 PM   #9
Tandem compressors will use a klixon type overload that is wired into the control circuit to disable both compressors in the event of a fault with one. You cant take them out though.
Trane Outside fan stopped working - cap or relay? JAWyrick HVAC 2 07-12-2011 12:03 PM
Relay help cody69 HVAC 4 02-11-2011 08:08 AM
Electric Baseboard Heat - relay problem? sporkman HVAC 7 11-21-2010 07:43 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 05:48 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
