-   -   time delay relay (http://www.diychatroom.com/f17/time-delay-relay-113631/)
savanhawkden 08-10-2011 07:40 PM
time delay relay
how do i by-pass time delay relay
hvac122 08-10-2011 08:34 PM
Why would you want to do that. What kind of system and delay are we talking about.
biggles 08-11-2011 06:40 PM
if it has 2 low voltage wires with the TD cut into inline jump them or remove them and wire nut them together..if you have more then 2 wires with 3 terminals need more info on what is it for
Master of Cold 08-11-2011 07:37 PM
If this is for the compressor I would opt to leave it in. The time delay will help protect the compressor during brown-outs.
biggles 08-11-2011 08:00 PM
my suggestion is only for if its not working if you jump it to see if the compressor comes on from a call from the stat...hope your talking TD and not an uverload KLIXON mounted in the terminal box cover of the compressor
SAMCRO 08-11-2011 08:10 PM
most modern a/c systems have td relays built into the t-stat to stop short cycling...jumping it/eliminating it from the circuit would be ok in this instance as it would be redundant to leave it in.:yes:
however if you have the old t87f the "round" t-stat or equivalent jump it to see if the sys. Contactor pulls in...if so the control is n/g and should be replaced....provided that you waited the predetermined time usually 5mins. When initially waiting for the sys. To run.
hope this helps..
Master of Cold 08-11-2011 08:43 PM
Klixon on a resi system?? Just how old are you??
Final Notice 08-11-2011 08:55 PM
that "klixon" mounted overload, what is that one used for? bigger compressors?
Master of Cold 08-11-2011 09:19 PM
Tandem compressors will use a klixon type overload that is wired into the control circuit to disable both compressors in the event of a fault with one. You cant take them out though.
