Time Delay Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 04:30 PM   #1
Rewards Points: 156
time delay fan
My older house had an American Standard heat pump. The fan in the air handler had a 30 second delay on it. When the thermostat switched off, the AHU blower would continue running for 30 seconds or so to dry out the A-coil. In my new home, it has an older Rheem oil furnace (about 20 years old, coupled with an old kenmore air conditioner) The system does great on humidity, but the coil is developing a "dirty sock" odor. I was wondering is if the same sort of delay device can be installed on the furnace's fan unit so that when the heat pump shuts off, the AHU will run a little while longer and dry out the coil.
av-geek is offline   Reply With Quote
Old 05-29-2012, 05:46 PM   #2
It takes close to 10 minutes for the air to dry off a coil. Turn the thermostat fan option to on and see if that solves your issue. That water going back into the air raises the humidity level in the house though,just a FYI. The 30-60 second blower off delays were to get a wee bit of free cooling since the coil was still cold from the cycle.
Old 05-29-2012, 05:48 PM   #3
FYI,
http://www.foxservice.com/austin/kno...eld=Categories
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
Weird light delay nikeman Electrical 7 04-04-2012 12:23 PM
How do I change the time? MNsawyergp Site Help and Suggestions 4 02-14-2012 07:25 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
tub backsplash delay time before last/first row? wraiththe Remodeling 6 12-13-2011 07:56 PM
