Through-wall Fan For Wood Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2007, 09:18 AM   #1
through-wall fan for wood heat
We heat primarily with a wood stove at the base of our stairway in an open-floorplan house, and the heat distributes quite well without fans. However, at night we like to keep the kids bedroom doors closed, and I'd like to install fans through their walls to circulate heat better at night.
I've found a purpose-made through-wall fan unit, but it's got white plastic grates, and it looks a little institutional. We'd prefer to put some nice wood grates over the fans, so I'm looking at coming up with my own solution.
I'm planning to use an in-line duct booster fan, and I'm wondering if anyone can recommend the quietest model. Also, I'd like to wire it to a controller or dimmer so I can control the fan speed. Is that possible with these fans?
I'll just fit these through the stud wall, and cover each side with a nice-looking grate.
Thanks, Nate
NateHanson is offline   Reply With Quote
Old 12-16-2007, 11:28 AM   #2
Union HVAC Tech.
You may not need heat if you run them on a dimmer to slow for long they will cause a nice fire on their own. You really need to get a fan made to be multi speed for this type of install. I'm sure if you google wood heating sites you will find a fan made for what you have in mind.
bigMikeB is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
