#1 |
Thoughts on furnace switch location
Hey Everyone! Thanks for these great forums. I'm a newbie, but the advice on here so far is much appreciated.
I'm Installing a new furnace. As it turns out, space is rather tight. I'd like to keep the electrical switch where it is, but it butts right up against the gas line. Does anyone see a problem with this layout? I'm thinking it's probably okay, but I thought I'd put the feelers out for some more advice. Thanks!! |
#2 |
Here's a pic of what I'm talking about:
Here's the URL: http://www.flickr.com/photos/orionm42/4972282810/ |
#3 |
fabrk8r
The toggle switch itself is against the gas line, or is it the switch box that is against the gas line?
As long as there is no interference with the operation of the switch and there is access to the switch it isn't a problem.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright |
#4 |
fabrk8r
Ok, after seeing the picture I would either move the box or the gas line. There is just not good access to that switch. Also, I see the cover plate is not on...that's a no-no too. You might want to take out those 1/4" hex head screws and use cover plate screws if the box isn't already stripped out.
What kind of gas pipe is that?
#5 |
Hvac Pro
Our gas inspectors would not allow that. Quality of workmanship clause. Not sure the electrical inspectors would either.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
As stated that's not good enough. Can't be anything blocking the normal access of the electrical box and that romex need to be in conduit, flex conduit is fine.
#7 |
An old Tradesmen
Wouldn't pass inspection here.
#8 |
Thoughts on furnace switch location |
#9 |
Hi all;
I'm going to work on moving this switch, and replacing the wiring, too. I'll take a pic when it's complete! Thanks! |
| Tags |
electrical, furnace, gas lines ![]() |
| Display Modes | |
| basic switch from 4-wire? | benepperson | Electrical | 6 | 08-17-2010 01:41 PM |
| No emergency cut off switch on my furnace | Red Squirrel | HVAC | 8 | 10-13-2009 08:09 PM |
| furnace pressure switch | Mike T. | HVAC | 3 | 10-10-2009 02:26 PM |
| Replacing a bathroom fan switch | cmacjr22 | Electrical | 4 | 11-04-2008 07:14 PM |
| HEIL furnace keeps kicking off reset switch | sunsetacres1318 | HVAC | 8 | 11-04-2008 09:35 AM |
