Though The Wall Vent Removal - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2008, 11:41 PM   #1
Though the wall vent removal
I have removed an old though the wall space heater….which went though a brick wall it is an 8 inch Vent.....for air intake and inside of the 8 is 4 inch for the flue. What I need is the plate ......A Terminal boot for the out side. ..Please advise me a what this part is truly called where to buy it......i will plaster the inside....however i need the plate for the outside
philiplouis is offline   Reply With Quote
Old 07-13-2008, 06:50 AM   #2
oops, did I do that!
You had a concentric vent.
8in vent caps are available at Home Depot or Lowes for a few dollars. They are made of galvanized metal and will last a couple of years before they rust.
A local sheetmetal shop can make a stainless steel vent cap for you that wont rust for quite a while.
If you need a plate, same thing... measure it up, and have a local sheetmetal shop make it up.
8 Ball is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
