Old 11-10-2007, 03:34 PM   #1
timthetoolman
Those darn register covers
So here's the annoying delima. I want to temporarly block off a heating register on the ceiling of a basement which still allows some warm air to leak when fully closed. At first for a quick fix, i duct taped cardboard over it to block the heat. This came off pretty quickly. So i picked up those magnet covers which seem to work well on wall registers, but always falls off that one on the ceiling. Is there a better product someone could refer me to??? If i get anymore irritated, im screwing a piece of sheet metal over the damn thing, but i want it to look good Thanks
timthetoolman is offline   Reply With Quote
Old 11-10-2007, 04:46 PM   #2
Custom Cabinet Maker
Just change the darn grill to one that has closeable/adjustable louvers!
skymaster is offline   Reply With Quote
Old 11-10-2007, 10:38 PM   #3
Either get a adjustable register or take the existing register out and put cardboard or whatever on the backside of the register and put it back up.
localtradesman is offline   Reply With Quote
Old 11-12-2007, 01:11 AM   #4
no loose ends
Seriously, dam the ducts. I've had customers that wanted to eliminate air into a room from the register but didn't want noise or unsightliness. Depending on duct construction or size, plastic lids work great. from coffee can lids to large paint can lids, you can get something to work.
Bear this in mind, if you go closing too many supply registers you could be generating other problems. Whether you know it or not, if a furnace doesn't get a certain amount of air through it, any number of devices or safeguards will become active and apparent failures could occur!
undone is offline   Reply With Quote
Old 12-30-2007, 07:51 PM   #5
I removed my vent, placed a piece of tinfoil on the back to block the heat and popped it back in. Works like a charm. " Elena
eardantz is offline   Reply With Quote
Replacing flush mount wooden floor vent (register) csteinke Flooring 3 09-30-2007 09:01 PM
Removing Paneling Seam Covers skittlzski Painting 1 08-08-2006 08:20 AM
add an additional register to a supply line b2v HVAC 1 06-20-2006 07:55 PM
Looking for the outlet covers! SandyM Painting 2 05-31-2005 10:41 PM
