Old 10-24-2011, 02:55 PM   #1
ACY
Things to look for when purchasing a used ductless split AC
Hi there…I’m in the market a ductless AC and I see many of these going up for sale on different used sites. Sometimes you might be lucky enough to see them still setup giving you a chance to try before you buy but more time then not they are already removed.
Are there things you can look for when considering to purchase a used system, a check list of sorts? I know that removal and how they are stored is very important as the systems internals should never be exposed to air…something about the fluid in them being hydroscopic
One unit I’m looking at is a LG LM-1830C2L, anyone know any details about this model?
ACY is offline   Reply With Quote
Old 10-24-2011, 03:58 PM   #2
biggles's Avatar
the condensing section should be stored in the positive either nitro or freon from being un-installed the evaporator won't hurt eiter but the dry and orifice can be changed on install..the coils and condenser fan condition some items to consider..original compressor might want to consider also
Why does a ductless mini split need to be a minimum of 5' off the floor? jayp HVAC 5 09-15-2011 12:12 PM
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 07:18 AM
Ductless mini split radecke HVAC 2 09-12-2010 02:50 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 06:23 AM
