Are These Good Products? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 08:16 PM   #1
Question
Are these good products?
We're in the process of buying a home, and the home inspector basically said that we need a new furnace and a/c. I was wondering if anyone knows anything about the following units and approximately how much they cost.
The furnace is an Amana AMH 9590 90k BTU, 2 stage, 95% efficient gas furnace.
The a/c is an Amana ASX 14042 3.5 ton 14+ SEER A/C unit.
Total cost to install everything would be about $6300.
Does this sound right?
Thanks.
acuteot is offline   Reply With Quote
Old 11-20-2008, 09:07 PM   #2
Sounds reasonable.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-21-2008, 05:55 AM   #3
An old Tradesmen
Rewards Points: 7,816
Sounds ok.
Is the current owner knocking money off toward the new furnace.
Old 11-21-2008, 06:05 AM   #4
Thanks for your answers.
Not a penny. We're pretty much getting a great deal on the house, because its a fixer upper - hence I'll probably be on here a bit
Old 11-21-2008, 06:10 AM   #5
An old Tradesmen
Have you thought about, making insulation, and infiltration improvements fist, before getting the new furnace.
By cutting down on the amount of heat the house needs, and getting the proper sized furnace, you can save a lot on your heating bill.
And also on the cooling bill if you have A/C.
Old 11-23-2008, 07:02 AM   #6
Yes, we're getting all of our windows replaced. We're also putting in insulation in the attic in the few places that there is some missing.
The current furnace is only a 55% efficient furnace, and I just can't bear the thought of having something so inefficient. I feel like all the above changes will really cut the heating bill and save me in the long run.
Old 11-23-2008, 07:11 AM   #7
An old Tradesmen
Do your improvements first.
Your current system may only be 55 ot 65% AFUE, but, when its cold out, and it runs for long periods of time, its far more efficient. More like 70 to 75% AFUE. And its SSE is more like 78 to 80%.
After the improvements are made to the house. You can have the proper sized system installed, and not pay for short cycling inefficiencies.
Old 11-23-2008, 07:14 AM   #8
There are other factors as well. The previous owner completely neglected the furnace, and had years ago removed the air filter only to never put it back. So all this condensation has built into the actual furnace. Also, its over 13 years old, so I figure it'll probably die soon anyway.
Additionally, we're doing all this before we even move in (there are other updates we're making to the house, so we're letting them do that before we move in), so I figured we should just get it all done and out of the way.
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
Good home construction software odigity Building & Construction 5 08-18-2008 11:53 AM
Good 1/2" corded drill? fw2007 Electrical 12 08-05-2008 06:21 PM
