Theromstat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 10:58 AM   #1
theromstat problem
when my heater or ac starts it shuts off after 1 minuete and then starts after 1 min. and then heats or cools to the set temp. wierd? thanks
mobilman5 is offline   Reply With Quote
Old 01-10-2012, 12:06 PM   #2
What type of thermostat do you have? also what is the make, model and serial number of your furnace/a/c ?
harleyrider is offline   Reply With Quote
Old 01-10-2012, 01:07 PM   #3
a/c
outdoor/25hna948a31 indoor/fe4anb006+ui- ser#2309e23021
carrier infiniti 2 stage t-stat
installed 7/09 thanks.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
