Old 11-20-2012, 08:09 PM   #1
Thermostats with fan speed programming?
I've just purchased a new Goodman heat pump and Air Handler. The air handler has a ECM fan motor and the brochure says the fan speed is variable. I'm guessing with the Comfortnet thermostat which costs about 379 dollars. It is a touchscreen etc..
I am wondering if there is a plain non-touchscreen thermostat I could buy with same programming capabilities as the Comfortnet thermostats costing alot less than 379 bucks.
Does anyone have any info to share?
Appreciate the help.
jfls49 is offline   Reply With Quote
Old 11-20-2012, 11:53 PM   #2
JJboy's Avatar
You will need Comfortnet thermostats (ctk01 ,ctk02, ctk03) only if you have communicating control features. You don't need these tstat if you system uses R,W,Y,G wires. The ECM motor still will be variable speed.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 11-21-2012, 04:24 PM   #3
An old Tradesmen
Rewards Points: 2,762
Only the Goodman communicating thermostat can control the fan speed directly. Other stats can send a signal to slow down, but not control the actual CFM.
Old 11-21-2012, 07:29 PM   #4
Only my Air Handler has the Comfortnet features. My outside Heat Pump unit does not. I am trying to find a cheaper alternative to the Comfortnet "touchscreen" thermostat.
I'm also wondering what features I am missing by not having the Comfortnet communications for the heat pump unit?
Anyone have any ideas?
Old 11-21-2012, 10:01 PM   #5
JJboy's Avatar
http://hvacrdistributionbusiness.com...l-system-0504/
Old 11-22-2012, 05:40 AM   #6
I have no experiance with the goodman communicating thermostat although the other brands I do have experiance with are worth the extra bucks do to the features they add to a system.
mrairflow is offline   Reply With Quote
replacing furnace blower motor from a 4 speed to 3 speed Roy Jones HVAC 4 08-08-2012 03:25 AM
how to hook up computer fan with fan speed control to cell phone charger aftermath431 Electrical 13 07-10-2012 04:31 AM
Fujitsu Ductless AC "Fan only" speed problem? chiefswabjockey HVAC 0 03-07-2012 10:21 AM
2 speed motor continues to run on slow speed Rob Fayette Electrical 2 11-13-2011 05:34 PM
Broan variable speed motor m0t0rgeo Electrical 1 09-22-2011 01:58 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
