#1 |
thermostats
replacing 2 seperate thermostats. 2 zone system, hot water baseboard, national gas, heat only, 2-wire 24vac, doesn't have to be programable with all the bells and whistles. Looking at some basic 2-wire honeywells right now. Any reccommendations? Use heating system about 5 months out of the year. It's turned off the rest of the time. Beenthere, canucker you've seen the pics of the system - what do you guys reccommend? thanks.
#2 |
Professional
thermostats
any heat only thermostat will work well. Mechanical? Digital? Personally I would use a Honeywell TH5110
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to hvactech126 For This Useful Post: | jmon (11-14-2012) |
#3 |
thermostats
thanks for your reccommendation
| Display Modes | |
| Using Two Thermostats Question | tim2255 | HVAC | 9 | 01-03-2012 11:13 PM |
| Lutron Thermostats | ChrisDIY | HVAC | 4 | 10-24-2011 09:45 AM |
| Electric Baseboard Heater Thermostats | Edward1 | Electrical | 11 | 02-19-2011 10:04 AM |
| 2 wire thermostats in parallel? | DragonFire | Electrical | 11 | 01-22-2011 01:50 PM |
| Control4 Thermostats Power Problem ?? | fluidimagery | HVAC | 11 | 12-03-2010 05:36 AM |
