thermostats
replacing 2 seperate thermostats. 2 zone system, hot water baseboard, national gas, heat only, 2-wire 24vac, doesn't have to be programable with all the bells and whistles. Looking at some basic 2-wire honeywells right now. Any reccommendations? Use heating system about 5 months out of the year. It's turned off the rest of the time. Beenthere, canucker you've seen the pics of the system - what do you guys reccommend? thanks.
any heat only thermostat will work well. Mechanical? Digital? Personally I would use a Honeywell TH5110
thanks for your reccommendation
I use the TH5110, and the TH4110 on those type of systems. Both can be battery operated.
thanks for your reccommendation - will do
| All times are GMT -4. The time now is 12:34 AM. |
