Thermostat Works Backwards - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 09:42 PM   #1
thermostat works backwards
just installed new thermostat, because could not get my outside a/c fan to kick on. After i installed new thermostat when i turn on heat mode my outside a/c unit comes on and blows cold air. I need help to figure out what i did wrong. i installed thermostat wires the same as on the old thermostat. Thanks for any and all help
duaned is offline   Reply With Quote
Old 04-13-2013, 09:53 PM   #2
Rewards Points: 252
Sounds like you just got a wire or two hooked up wrong somewhere (common error). Sometimes new stat terminal maybe a little different than old stat. Can you please post a pic of the thermostat terminal and control board terminal on hvac unit? Also name and model of stat. Thanks.
jmon is offline   Reply With Quote
Old 04-13-2013, 09:59 PM   #3
Did you try switching the wires. It's probably just your new thermostat is backwards from the old one
jsbuilders is offline   Reply With Quote
Old 04-14-2013, 03:44 AM   #4
biggles's Avatar
if your just typical R,G,Y1,W1 flip the W and Y wires shut furnace toggle off on that 115 just incase you spark one of them....
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Need your help - Thermostat catpace HVAC 4 03-05-2011 10:24 PM
Installing New thermostat need help effusion_01 HVAC 18 03-01-2011 05:09 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Odd Thermostat "Fan On" issue TJ_in_IL HVAC 9 03-30-2010 09:05 PM
