Thermostat Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 09:59 PM   #1
Rewards Points: 12
thermostat won't shut off
I have a white rodgers digital comfort set ii therm and a ruud heat pump (installed in 1994). The problem I have is that once the desired temperature is reached, the thermostat will not shut off. It will blow cool air for 15 mins and then begin to heat the house for 30 minutes. This problem only occurs when heating and is intermittant: sometimes (mornings) it works perfectly.
I know that if the next heating setting is several degrees hotter the system will run in preparation for that temperature, but my system will run for 1.5 hours or more at the same temp if I don't manually turn it off. Please help!
akeredun is offline   Reply With Quote
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 06:51 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 02:22 PM
with all bedroom doors shut does thermostat read correct temp? windowguy HVAC 19 04-20-2009 08:17 AM
