Thermostat Wiring-Transformer (where To?) - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 10:44 AM   #1
Thermostat Wiring-Transformer (where to?)
Hello all!
I had a complete new HVAC system installed for the downstairs portion of my house. The installation required a new t-stat since it is a 2-stage cooling system.
I really like the features on the new t-stat, and purchased one for my slightly older 1-stage upstairs HVAC system as well. One of the features I like is that it runs on household power, using the batteries for a backup. It's my understanding that I've already basically got power to the t-stat via the R wires, and that I just need to add the common to basically complete the circuit.
I looked at the wiring to the internal board, and there is a wire running to the common, which runs to a "safe-t-switch," and then continues on to somewhere I can't locate. There is a separate bundle of wires that runs to the t-stat. Can I use one of the unused wires in this bundle and ALSO connect it to the common on the board, or will that mess up the "safe-t-switch?"
System is a Frigidaire with the following model numbers:
Condenser FS3BD-030K
Furnace L1RA-054C12A
Coil C5BH-T30C-B
Photos:
Circuit Board:
Wires leaving furnace:
Old t-stat connections (was an old Hunter t-stat):
Quagmire is offline   Reply With Quote
Old 04-04-2011, 10:45 AM   #2
One More thing...
The new t-stat is a Honeywell VisionPRO 8000 (TH8320U1008)
Old 04-04-2011, 03:35 PM   #3
An old Tradesmen
Rewards Points: 7,328
Yes, you can just connect it to the furnace's common terminal.
question on old thermostat wiring for upgrade jthn HVAC 2 01-02-2011 11:07 PM
Problem Wiring Thermostat MichaelLR Electrical 9 12-20-2010 03:20 PM
Thermostat wiring question tgeb HVAC 3 11-19-2010 04:08 PM
Wiring My Thermostat...Please Help Solve Puzzle! :) IdahoGirl HVAC 31 05-15-2010 02:31 AM
thermostat wiring for electric heater Captflx HVAC 3 03-05-2010 08:48 PM
