Thermostat Wiring Help Needed.... - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 12:43 PM   #1
I bought a new programmable thermostat to replace the current Carrier HP model for Weathermaker 8000.
Carrier wiring:
Red to R
Green to G
Yellow to Y
White to W
Blue to O/W2
Brown to C
New thermostat has terminals for RH, RC, G, Y, W, O, B
I taped up the brown common wire and wired the rest as follows:
Red to RH jumpered to RC
Green to G
Yellow to Y
White to W
Blue to O
The a/c works fine. When switched to heat, the thermostat is able to trigger the fan but it never gets hot. Hopefully just a wiring issue? I was going to wire the old one back up today and try turning the heat on. I just bought the house so I have not used the heat yet. I was wondering if I have the White and Blue wires backwards on the new thermostat?
Thanks.
MistaBusta is offline   Reply With Quote
Old 08-23-2011, 03:37 PM   #2
newtech's Avatar
Rewards Points: 164
newtech is offline   Reply With Quote
Old 08-23-2011, 03:54 PM   #3
JJboy's Avatar
DO you have heat pump system?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-23-2011, 04:57 PM   #4
An old Tradesmen
Rewards Points: 7,370
Post brand and model number of new thermostat.
Old 08-23-2011, 07:57 PM   #5
White Rodgers 1F78-151. The unit is a carrier weathermaker 8000 and the old carrier thermostat model # includes "HP" for heat pump. Thanks
Old 08-23-2011, 11:22 PM   #6
See if this helps:
http://thermostats.highperformancehv...g-colors-code/
diyorpay is offline   Reply With Quote
Old 08-24-2011, 04:28 AM   #7
An old Tradesmen
That thermostat requires a jumper from W to Y to run the heat pump in heat mode. Unfortunately it doesn't have the ability to run aux heat. So you'll need to take it back, and get one that can run aux heat.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (08-24-2011)
Old 08-24-2011, 07:45 PM   #8
Dammit. Thanks
Old 08-24-2011, 07:57 PM   #9
So I need a 2H/1C for heat pump?
Old 08-25-2011, 01:06 AM   #10
If you can find it local, or put the old one back for a bit for mailorder, very reasonable for what it does.
LuxPro Everthing Stat - PSP722E, 7 day programmable, 1 or 2 stage heat and/or cool
I found too many Heat Pump stats dropped to stage 2 (aux) heat if stage 1 (HP) ran for too long.
Well, that just killed the whole energy savings of a HP by turning it off after 30 min of running.
Shoot, if it runs constantly and keeps the temp at set point, why do I need aux heat, it's exactly balanced system then with the current outdoor temp!
The LuxPro allows setting that Stage 2 specifically as to when it kicks in. Maybe when your HP looses a whole degree in it's effort, or 2 degrees, or 1/2 degree, ect. Too low and a briefly opened door causes what may appear to be a loosing battle, but it's really a temporary dip.
heybales is offline   Reply With Quote
Old 08-25-2011, 04:19 AM   #11
An old Tradesmen
Yes, you need 2 heat 1 cool, or better.
Many thermostats are listed as heat pump capable, but you need to read the description to make sure that it can operate the heat pump and aux heat.
Old 09-02-2011, 05:28 PM   #12
Ok. I bought the LuxPro Everything Stat PSP722E. Still having problems. Please help
Carrier wiring:
Red to R
Green to G
Yellow to Y/Y2
White to W
Blue to O/W2
Brown to C
LuxPro
RH
RC
G
C
W1
W2
Y1
Y2
E
O
B
Lux Pro has RC and RH jumpered so I know I'll wire Red to RH. Green will go to G, Brown will go to C. I assume White will go to W1. I'm not sure about blue....is it O or W2? My old thermostat has a Y1 which is left open and yellow is in Y/Y2. I don't believe yellow goes to Y2 on LuxPro? Also, the new thermostat has E and B terminals but says O and B can not both be used. I'm lost
Old 09-02-2011, 09:00 PM   #13
An old Tradesmen
Yellow to Y1, and Blue to O.
MistaBusta (09-02-2011)
Old 09-02-2011, 10:03 PM   #14
CHEERS!
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
Wiring Thermostat for HVAC UncaYimmy HVAC 8 05-07-2010 04:51 AM
Thermostat wiring help sords HVAC 10 01-01-2010 01:45 PM
Thermostat wiring question cpuken HVAC 4 12-14-2009 07:32 PM
thermostat wiring sourmash HVAC 1 07-18-2009 10:17 PM
