Thermostat Wiring HELP - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 06:31 PM   #1
Thermostat wiring HELP
ok i am in need of some help. i had an old t-stat that was swaped out. owner didnt wire it right. only the a/c worked..... when i wired the colors to the corresponding letters only the heat works and i can hear a slight hum from the AHU outside. its a honeywell t-stat. i even tryed to check the wiring diagram on the unit outside and the colors dont match up. i tryed but i think they spliced different wire colors together. the house is about 25 years old.
i have included a pic of how the wiring looked when just a/c worked and then when the heat works. (is hum sound normal) ?
any ideas?
its starting to get cold and i just wanna make sure the heat works right.
any more info needed?
espi69 is offline   Reply With Quote
Old 01-03-2012, 06:58 PM   #2
MarginallyQualified
Rewards Points: 2,464
do you have a furnace or a heat pump?
whichever that may be... is this t-stat intended for a furnace or a heat pump?
last... what color wires do you have to work with (from in the wall)?
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
plummen (01-18-2012)
Old 01-03-2012, 07:42 PM   #3
When wire colors change disconnect both ends then twist 2 together and check for continuity. Unhook those 2 and do the same with all the wires.
I had one a few years back that some joker spliced 3 times and changed colors at each splice.
Old 01-03-2012, 08:17 PM   #4
Rewards Points: 492
W - call for heat - usually white
Y - call for A/C - usually yellow
G - call for fan - usually green
Rc - power for cooling
R or Rh - power for heat
O - heat pump brands other than Rheem & Ruud (cooling mode)
B - heat pump Rheem & Ruud brands (heat mode)
Can't tell if your Rc and R(Rh) terminals are jumped. Many are. It's to supply power to both heat and A/C. The incoming red wire is likely power supply. I would leave wiring as in first pic and jump Rc and R. If no jumper, move red wire from Rc and place on R(Rh).
diyorpay is offline   Reply With Quote
Old 01-03-2012, 08:28 PM   #5
it is in fact jumpered for the 2 R's . its electric heat. outside with the condensor a/c unit. i will get make and model info tomorrow when its light out if it helps. i appreciate the super fast response guys.
Old 01-03-2012, 08:40 PM   #6
i will attempt a continuity test tomorrow thanks guys
Old 01-03-2012, 08:43 PM   #7
want heat tonight? connect white to W and red to rc/r leave all others off
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
ben's plumbing (01-03-2012)
Old 01-04-2012, 04:44 PM   #8
UNIT outside
Side Skicker with model info
Inside access panel of unit.
Board with wires
OK well i hope these pics can help.
i tryed wiring as the diagram says and unit make a click click click sound.
sooooooo...... i also noticed no green wire is connected to the unit but green wire is at the T-stat.
when checking for continuity , if it reads 0.0 and doesnt bounce around then i guess its ok. what would be the next step once doing this.?
Old 01-06-2012, 10:49 AM   #9
any ideas?
Old 01-06-2012, 11:03 AM   #10
MarginallyQualified
any ideas?
Originally Posted by harleyrider View Post
want heat tonight (1/3/12)?
did this suggestion from 3 days ago work?
Old 01-06-2012, 11:13 AM   #11
Rewards Points: 492
Outdoor wiring in pics looks correct.
If you want to try.
In your original 2 thermostat pics: In second one for heat,
Put R red wire back on jumpered Rc/R terminals
Put Y yellow wire back on Y terminal
Best guess: Put purple (wildcard) on O terminal (heatpump)
Old 01-18-2012, 08:42 AM   #12
Rewards Points: 330
fan on?
will this turn on the fan(green wire)
kt82 is offline   Reply With Quote
Old 01-18-2012, 08:46 PM   #13
Anytime I have ever installed a honeywell tstat like this the blue wire needs to be on C, The yellow wire on Y, the white wire on W, the green wire on G, and the red wire on either R or Rc since they should be jumpered from the factory. Since it is not a heat pump, and if the installer wired the low voltage like any other technician would do...that should enable you to have a wire for common, main power, fan blower, compressor, and heat. That is all.
ZBat910 is offline   Reply With Quote
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 12:49 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
