Thermostat Wiring Driving Me Mad - HVAC - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 09:17 PM   #1
Thermostat wiring driving me mad
I installed a 7 day programmable thermostat for my mom at the end of fall last year. I thought I had everything hooked up correctly until she needed the A/C. I don't know why this is racking my brain so much. But I just can't seem to figure out how to wire it. The furnace and the fan work. I messed around with it today and I got the A/C running using the setup pictured. The a/c did run, but the fan on the a/c unit turned off and I could hear the compressor still going (is that normal?) it's only 72 out. I realized I didn't pull the number 3 jumper, so I pulled it. It's working, but since there wasn't a wiring diagram for my unit, I just wanted to have a seasoned pros take a look at what I did. Feel free to make fun if I did something stupid.
Oh and that is orange hooked up to the yellow.
I have it turned off until I can actually figure this out, going to be 90 tomorrow and the HVAC guy I usually use can't be out until Thursday.
Any help would be very very appreciated.
Installation Manual:
Pictures: The wiring diagram made was using the current wire setup in the home, the only thing I don't seem to understand is the actual connection to the thermostat.
BatHunters is offline   Reply With Quote
Old 05-13-2013, 09:45 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Furnace - Stat
R-R (24 volts)
W-W (heat)
Y-Y (cool)
G-G (fan)
C-C (common, for digital stats)
Furnace to outside Condensing unit
Y to either low voltage wire
C to either low voltage wire
so you are going to have two wires on the Y terminal of the furnace and two to the C terminal if you're using a c from furnace to the stat. if no common to the stat from furnace then only the C from the furnace to the condensing unit. It does not matter which wire you connect to at the condenser from the furnace, meaning the y and c can go to either low voltage wire in the condenser.
i don't think you're even messing with the condensing unit outside, but most likely you messed it up in the furnace. anyways, hope that helps.
Doc Holliday is offline   Reply With Quote
Old 05-13-2013, 10:46 PM   #3
Rewards Points: 1,208
There should be a jumper from RH to RC on the thermostat.
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
HVAC1000 (05-13-2013)
thermostat wiring rejames HVAC 11 05-02-2012 08:07 PM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
