-   -   Thermostat Wiring Assistance (http://www.diychatroom.com/f17/thermostat-wiring-assistance-39772/)
2SLO 03-06-2009 02:07 PM
Purchased the Honeywell YTHX9321R5003 -Prestige HD Comfort System Kit for my newly constructed home. I have replaced thermostats in the past without issue and wondering if the unit I receive is defective given its inability to turn on.
I have a Heat Only Plus Fan - Gas System - 24V Etc
I wired up the new thermostat exactly as my old thermostat:
Red Wire = R (With Jumper located in R and Rc)
White Wire = W
Green Wire = G
Wire NOT used on old thermostat > Brown, Blue, Yellow
The directions said the C (Common) can be used (not should be) and from my research it appeared the Brown wire would be the C Wire. I tried the blue wire too in the C slot > No luck!
Am I missing something obvious here?
Thanks!
Brian
air works 03-08-2009 06:21 PM
t-stat.
you should have aleast 4 wires on a staight cool system.Im not to filmilair with that stat,but there all pretty similiar,it goes r to red /green to g which is fan/white to w,which is heat/yellow to y,which is cool.as far as blue goes,its used as a common c,or sometimes b.if this is a digital stat you will need the common unless there is batteries.the batteries feed the display light,but a common can do this too and make your batteries last longer..the batteries also provide memory in case of power loss.if its not a digital and works of a mercury switch then you shouldnt need the common
bl19811 04-02-2009 09:12 PM
The best thing to do is to look at the cirrcuit board on your furnace and you should see your thermo stat connections, for the blue and brown one is for common and the other can be used for either a heat pump or a humidifier, the best thing to do is to look at the wiring diagram on your furnace and see how it is wired.
biggles 04-03-2009 05:44 AM
if the new stat is digital with a LED screen it might need a constant 24Vs up on the subbase to power itself.color doesn't matter but choose one not used then catch the other side of the TR in the furnace,and connect it to the C on the subbase.the old stat worked on a feed back from W or G during a call to run the unit and the stat.
kennzz05 04-04-2009 02:03 AM
2slo the extra wires you tried hooking up to the c terminal, blue and brown i think you said are likely not hooked up to anything in your furnace. thats why you had no result after trying to use those colors, chose one of the 2 colors you mentioned, usually blue for common than go to your furnace and hook up that same color at the location where the other wires are tied in. hooking it to the c term inside the furnace. this will likely solve your problems. good luck.
PLEASE AWARD ME THE DUMBASS AWARD I JUST REALISED THIS POST WAS A MONTH OLD, IM GUESSING ITS BEEN LONG FIXED
hvaclover 04-04-2009 04:04 PM
Das' ok Kenny. I do that a lot too.
OldCountry 12-11-2009 12:17 PM
I'm glad you replied. I just installed my Prestige HD night before last and wasn't sure why it wasn't working. I had a pretty good idea that nothing was hooked up to the "C" terminal at the furnace, but I might not have spent the five minutes it took to verify it and fix it had I not seen your post.
