Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2015, 09:46 PM   #1
Rewards Points: 4
Question
Thermostat wiring
I have novice electrical experience, but I'm unfamiliar with HVAC setups. Last year I purchased a new thermostat for an older house, but I'm only now getting around to hooking it up. As best as I can tell one of the previous owners had a unit that was 5-wire, but the current unit is only four:
I've confirmed all five wires (blue, yellow, green, red, and white) feed through the house and to the thermostat - except the blue. It's not connected at the unit or the current thermostat. Here's the diagram for the unit:
The thermostat is a Insteon 2441TH, which uses five wires (I believe I'm only missing the Common). I also have a Venstar Add-A-Wire, but I'm not sure how to wire it up (if it is even needed). All the Venstar examples refer to wire colors or designations that aren't obvious in this setup. I'm stumped with what I need to wire together; any help with what I actually need to connect would be appreciated.
cyberdelic is offline   Reply With Quote
Old 05-21-2015, 10:19 PM   #2
Rewards Points: 3,256
If you need a common just hook the blue to a convenient spot on the 24 volt side of the transformer. That would be the lower right part of the transformer in the diagram. Gray or black wires.
zappa is offline   Reply With Quote
Old 05-24-2015, 03:07 PM   #3
Rewards Points: 1,989
You have to connect the blue to the 24 VAC sise of the reansformer that is opposite polarity to that qwhich is connected to the red wire going to the tstat .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Wiring Lux PSP722e thermostat to Carrier Performance Heat Pump Stevo F HVAC 2 11-01-2014 05:26 PM
thermostat wiring ice109 HVAC 9 05-20-2013 09:58 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
