Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 05-14-2008, 02:58 PM   #1
thermostat wiring
I have a ICP Model#phx330000k00a1. I also have bought a honeywell focuspro 5000 (THE5320U1001) thermostat non-programmable. I believe I have 2 heat and 2 cool stages on my heat pump. Can anyone help me with the wiring of the two. The heat pump has a G, R, Y1, W2, Y2, W3,C and the stat has r, rc jumped Y2,W2,G,W,C,Y thanks for any help
toddc is offline   Reply With Quote
Old 05-14-2008, 09:41 PM   #2
I'm not familiar with ICP, but it appears this is your indoor unit not your heat pump. Also, the thermostat does not appear to be a heat pump t-stat. heat pump stats will also have an O terminal as well for the reversing valve in addition to the terminals you mentioned, unless you just overlooked it.
How many wires do you have? What is hooked up to where on your indoor unit? I'll be glad to help, but need more info.
sgthvac is offline   Reply With Quote
Old 05-14-2008, 10:44 PM   #3
Read the post on thermostat wiring by #CARRIER at:
Facts about thermostats
Mike
Mike Warner is offline   Reply With Quote
Old 05-15-2008, 04:27 PM   #4
Yes you are right the t-stat also has L,Y2,AUX/E,G,O/B,C,Y,R,RC I have 8 wires, don't know what you mean by indoor unit
Old 06-05-2008, 08:50 PM   #5
hmmmmmmmmm
ro9beam2002 is offline   Reply With Quote
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
Wiring a Noma Programable Thermostat 111jag General DIY Discussions 1 10-14-2007 10:13 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 09:22 AM
