Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 09:57 AM   #1
Thermostat wiring
OK I have picked up a Honeywell RTH7600 and am wiring it to a goodman 2 stage with no heat pump.
I am going to replace the existing 2 wires with a 4 wire hooked up to R G W1 W2 In the thermostat itself I see that R and RC are jumpered together. Should this be changed?? Thanks
Bluenoser60 is offline   Reply With Quote
Old 01-31-2012, 10:03 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
No. But you need to know whether that furnace can accept a w2 wire as the cheaper versions of it cannot. they use a timer to engage the 2nd stage after 7-10 mins and not the w2 term. if it has a w2 then there is a dip switch on the board that needs changing to use the w2. if it cannot use w2 then use r/rc and w and U are OK. if you run 4 wires then hookup C and U won't need to change batteries. I would run 6 wires in case U use AC later.
Old 01-31-2012, 11:08 AM   #3
yes it has W1 W2
It is GMVC95
Old 01-31-2012, 11:26 AM   #4
Hvac Pro
yuri's Avatar
VERY nice furnace. U need to read the install manual as there should be a dip switch on the board to allow it to use the w2, some have a pin jumper but that info should be in the install manual. I would run 18/6 wires and use r, w1,w2,c, g that way you can run the fan for circulation with the g wire, later the y can run an AC. HDepot may have that wire by the foot off a roll or buy a roll.
Old 01-31-2012, 01:53 PM   #5
Thanks for info!!!
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 12:49 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
