Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 04:41 AM   #1
Thermostat Wiring
I have a White Rodgers Type 1F57W-314 tstat that I need to wire to my furnace/ac unit. The Tstat has the following terminals on it, Y1, Y2, R, G, W1 & W2. The furnace has the following terminals on it, C, G, R, Y, W1 & W2. The W1 & W2 terminals in the furnace/ac unit were jumpered together, I don't think they need to be? Can anyone tell me how to connect the Tstat to the furnace/ac unit?
Blacktitan is offline   Reply With Quote
Old 10-16-2011, 06:54 AM   #2
raylo32's Avatar
Rewards Points: 1,294
It sounds like you have a 2 stage heat furnace that was set up to run with a single stage tstat. Did you old stat have just a single W and not a W1 and W2? It would help if you could post your furnace make/model. But assuming it is a 2 stage unit you would pull the W1/W2 jumper, then connect the wires on stat to furnace: Y1 to Y, W1 to W1, W2 to W2, G to G, R to R.
Or if you didn't want to run it as a 2-stage (can't imagine why you would not use the feature if you have it) you could leave the W1/W2 jumper in place and just connect W1 from the stat to the jumpered W1/W2 on the furnace.
The new stat has no C terminal so I assume that it runs off batteries.... or is not programmable.
raylo32 is offline   Reply With Quote
Old 10-16-2011, 06:54 AM   #3
An old Tradesmen
Rewards Points: 7,816
Terminal to terminal. If your A/C isn't 2 stage, then Y1 of the thermostat should go to Y2/Y. May also need to reset your furn ace control board to use a 2 stage heat thermostat.
Old 10-16-2011, 07:21 AM   #4
biggles's Avatar
the new stat is working on a back feed not needing the C for a constant 24V at the subbase if you shut the emergency switch on the furnace you'll see batt ID come up.if the manual doesn't show a C or the base your good.many a home owner runs out gets the latest stat with a ton of digital and then they see a C call and wonder where it is from the furnace with the older one not needing it
Old 10-16-2011, 08:46 AM   #5
T stat Wiring
Thanks guys for the info. The Tstat is not a programable model, nor is it battery powered. I tried looking for a manual on line, and discovered it is obsolete, so any info would be greatly appreciated.
From what I have read from you guys, it looks like I only require 5 wires? What about Y2 on the Tstat?
Thanks again
Old 10-16-2011, 09:02 AM   #6
raylo32's Avatar
Y2 would be for 2-stage air conditioning condenser which the furnace board doesn't support (since it lacks a Y2 terminal) and which you surely don't have. So you don't need to connect anything to that terminal on the stat.
Thanks again
Old 10-16-2011, 09:25 AM   #7
AKA HVACTECHFW
Rewards Points: 1,208
that is a mechanical stat! Go buy a digital! Also post the make and model of your furnace.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-17-2011, 11:21 PM   #8
T stat Wiring
Thanks guys,
The furnace is a Bard wall mount model #WE701-F14EPXXXJ. I have hooked it as as advised and everything seems to work even though I have not connected the "C" terminal. I agree that this is a lousy mechanical Tstat, but due to my location in the middle of Siberia, I can't run down to Home Depot and by an electronic model. LOL. Thanks for all your help!! I greatly appreciate it!
Tags
hvac installation , thermostat help
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 09:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 11:49 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 07:32 PM
