Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 11:02 AM   #1
Thermostat wiring
Can a heat pump thermostat be used in a ac only system?
crosway is offline   Reply With Quote
Old 06-02-2011, 12:53 PM   #2
Rewards Points: 6,652
Yes, just make sure that it is compatible with the type of system you have. All a Heat pump is, is a glorified air conditioner, but with a reversing valve to change the direction of the freon depending on if wanting to heat or cool.
Old 06-07-2011, 06:19 PM   #3
Rewards Points: 392
Model numbers would help here. So you have a AC unit and a thermostat that runs a heatpump? Depending on the thermostat it may have a setup setting to control just a standard AC unit. The AC units are very simple. Two wires to turn on the relay to start the compressor and fan. Heat pumps have power (red), ground(blue or green), call for backup heat (white), Compressor turn on (yellow wire) and reversing valve (orange).
zootjeff is offline   Reply With Quote
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 12:49 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
