Thermostat Wires - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 10:17 PM   #1
thermostat wires
I was replacing old honeywell thermostatwith a new honeywell CT50K thermostat. the new thermostat has letters for connecting wires.the old one does not.One wire is black and one wire is white,where do they go on new thermostat?
Turko is offline   Reply With Quote
Old 10-10-2011, 10:28 PM   #2
Houston204's Avatar
Rewards Points: 556
http://customer.honeywell.com/techli...0s/67-5167.pdf
black to R and white to W
Houston204 is offline   Reply With Quote
Old 10-11-2011, 01:40 AM   #3
REP
Before you connect those wires to the stat,make sure they are low voltage and not line voltage.If they are line voltage you have the wrong stat./
REP is offline   Reply With Quote
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
2 stage thermostat with old wiring (4 wires)? bigbug HVAC 2 06-22-2010 01:34 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
