Thermostat Wire Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 01:33 PM   #1
Rewards Points: 150
Greetings,
I would like to rewire my thermostat, and relocate my Humidstat to the house, instead of the basement. This would require 6 conductors.
My question is, can I use 18/6 Stranded as opposed to Solid? I have several rolls of stranded from my alarm days, and cannot see buying new wire if not needed. The total run is only about 30ft. Currently there is 20/4 running to the thermostat. Both the thermostat and furnace contol board have compression type screw terminals, not the kind you wrap the wire around.
Thanks in advance for your thoughts.
TJ_in_IL is offline   Reply With Quote
Old 10-16-2009, 01:39 PM   #2
IMHO
yes on the stranded, yes on the gauge, yes on the distance.
For the connectors you may want to tin the wire ends but be careful the solder doesn't wick up into the insulation.
Old 10-16-2009, 01:48 PM   #3
Rewards Points: 150
Thanks for the quick reply. I was going to tin anyway, but wondering why the caution about wicking? I have never heard of that warning before.
TJ
Old 10-16-2009, 01:53 PM   #4
TJ
If the wire is flexed, where the wicking stops there will be a sharp bend radius leading to breakage at that point.
All stranded or all solid wire gives a uniform large or small bend radius when flexed.
In this application it may not matter.
Old 10-16-2009, 01:55 PM   #5
Rewards Points: 150
Fair enough. Thanks again.
Old 10-16-2009, 06:57 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
Use #18 stakon crimp connectors with eyelet ends on the board for a neat job. Not sure about the tstat.
Electrical wire size question. shawnlee Electrical 11 08-11-2009 07:25 PM
wire running question ponch37300 Electrical 4 04-21-2009 04:58 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Thermostat Question Dekuyper Electrical 4 06-26-2008 08:49 AM
Thermostat question MsApril HVAC 1 02-09-2008 07:00 PM
