Thermostat Went Out No A/C Or Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 08:18 AM   #1
Thermostat went out no A/C or heat
I'm new here..sorry if I posted in the wrong place.
I moved my thermostat to heat yesterday and as soon as I did my thermostat went out and the A/C and heat do not work.
Breaker wasn't tripped and the switch on the furnace was on.
I went out and bought a new thermostat and it's still not working.
Please help... with any possible suggestions
mommeetiff is offline   Reply With Quote
Old 11-01-2010, 02:20 PM   #2
HVAC / Plumbing
If your unit has a circuit board with fuse. check for blown fuse
kenmac is offline   Reply With Quote
Old 11-04-2010, 06:00 PM   #3
Furnace - blown fuse
There was a blown 5 Amp fuse inside the furnace and the board. Changed the fuse and it blew again as soon as I moved the thermostat to heat. Changed fuse and tried again still the same thing. Any suggestions on what I can do next?
Old 11-04-2010, 09:17 PM   #4
HVAC / Plumbing
Look for a short somewhere in the low voltage wires
Old 11-04-2010, 09:23 PM   #5
Carefully take the faceplate off of the thermostat and look for unshielded wires touching. I would do the same thing inside of the furnace. Can you think of any holes you nailed or drilled into the wall near your thermostat? I have actually seen that short out low voltage wire.
berend is offline   Reply With Quote
Old 11-05-2010, 07:15 PM   #6
biggles's Avatar
that the fuse is blowing out narrows it down to the furnace heat controls or the actual wire run up to the stat for heat...doubt that.remove the board and inspect the back for burnt marks..try refuse it with it not mounted slide piece of cardboard to support it..then call for heat again..the only other loads that are in that 5 amp fuse draw are the ignitor and gas valve..might need a tech visit...but try the unmonted board with new fuse and heat call
Old 11-06-2010, 10:21 AM   #7
Thank y'all for your help. I decided to leave it to a professional. The tech said it was a short. He fixed it and we have heat now. It was $100 out of pocket but I would've probably screwed things up more and ended up paying more if I kept messin around. Just wanted to let y'all know I appreciated the replies.
Replacing a two wire heat thermostat to a four wire cibao67 Electrical 2 03-01-2010 09:42 AM
An efficient programmable thermostat for a heat pump? mow2000 HVAC 17 01-16-2010 09:09 PM
Heat & fan work when wired but not with thermostat. twocities HVAC 1 10-20-2009 10:41 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
Heat kicks on without thermostat bgd73 HVAC 1 05-23-2008 09:17 PM
