Thermostat Type Needed With Temp-a-trol MSC-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2008, 06:48 PM   #1
thermostat type needed with temp-a-trol MSC-3
Hi everyone.
I updated my thermostat's last fall to Honeywell RTH110B's (home depot)which have heat/off/cool switch and fan auto/on switch (non programable), previously I had the old style mercury dial thermostat's and in my basement I have a honeywell temp-a-trol MSC-3 switch that I can set the fan on or auto and heat/fan/off/cool. In the fall I was able to get the heat to work but now am unable to get the ac to work unless I put the white wire on the Y port, but when I do that it doesn't turn off when it reachs the desired temp set. Each zone has 3 wires, bedroom has red/white/ has red/white/blue. The new digital thermostat
has Rh RC (with jumper) W Y G. I had the red wire on Rh, white on W, and blue (bedroom)/black(kitchen) on G and the heat worked but now when I switched the MSC-3 to cool I get no ac. I'm thinking I need to get different thermostat's that just control temp and not the same functions as the MSC-3 but I'm stuck and not sure. Any help would be greatly appreciated!
Thanks, Joe
PS. its 86 in the house....HELP
joe c is offline   Reply With Quote
Old 06-13-2008, 06:12 PM   #2
Rewards Points: 150
go to the air handler disconnect power open cabenit y is ac g is fan look to see what colors they used and match at t stat if you heat and cool are controlled by different system ie. hot water base board and a seperat ac system you need to look for what coler they used for r and remove the jumper rh heat rc cool 24 v supply
geo fan is offline   Reply With Quote
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 09:11 AM
Odd Thermostat set-up, help needed Dan1 Electrical 3 10-08-2007 11:12 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
